Afternoon swap for the alternative Roman numeral dial version of the Yema N81W53. I had to get this one out, because when I put the other one back in its collection box slot, I noticed it was doing the 'two-second two-step' (low battery).
- rsz_p1720053-crop.jpg (243.37 KiB) Viewed 7587 times
Apart from some slight deterioration of the blueing on the 1/10s and constant seconds sub-dial hands, this example is in almost NOS condition. Or at least it was when I bought it, over 10 years ago
from Indonesian blogspot seller Kucimo, way back in September 2010. It also came fitted with the correct original Yema 19mm ribbed black leather strap ....
- Yema-N81W53-DressChrono-ForSale(kucimoinc.blogspot.com)-August2010-1.jpg (131.74 KiB) Viewed 7586 times
.... which sacrilegious as it may sound, like my other N81W53, I replaced with a black Barington Ostrich Leg strap. Funnily enough, the original Yema black ribbed leather strap ended up on another of my gold-dialed N81W63's.
Incidentally, after I'd replaced the battery, tightly screwed down the case-back and removed it from my nylon pegged watch case vice, I noticed what at first appeared to be a mark on the side of the case, above the 10 o'clock pusher.
- rsz_p1720051.jpg (110.94 KiB) Viewed 7565 times
But it couldn't be - I'm always so careful when doing this routine task. Zooming in on it (apologies for poor flash-lit shot)
- rsz_p1720052.jpg (138.79 KiB) Viewed 7565 times
It appears to be some kind of hallmark, which reads 9
♡9. With my limited knowledge of hallmarks, and given the watch case construction (plated base metal), it doesn't make any sense to me.
After spotting this, I got my other N81W53 back out again to check it. It has the same stamping, but the on other side of the 10 o'clock pusher.
