Hi Paul
Thanks a lot for your quick reply and for all the research you have done already!
If you don't see any difference in specs for the YM04A (other than the color of the date plate), and I see the same, then I guess I am good going with the YM04A
Thanks for researching the links!
I also found it on Aliexpress a little cheaper, but it has no stem that come with it:
https://www.aliexpress.com/item/1005008253433926.html
Would you know where to get a stem and O-ring seal that fits the YM04A movement?
(With the parts number from the Seiko database I can find one listing, which is from the US an would end up being quite expensive:
https://www.ebay.co.uk/itm/135072306470 - do you know of other options? Or what to search for?)
The current stem is not useable, i.e. it has a bend to it, so it is not completely straight anymore and has troubles turning. I attach a picture.
Or do you see any possibility in restoring it?
It really looks like it is the SPC235P1 - I am amazed you could recognize it just so
You mention that we would need the caseback number. I have included a picture, does that bring us closer?
Regarding the hand, google returns almost no results searching for the parts number, and ebay returns zero.
Buying from the UK would result in very high additional tax costs since they are not part of the EU, so that is not a possibility.
Would you know other hands that look like them, but are easily available and common? Or what search terms could I use to find one? I can live with a little difference, that even adds a personal touch
I also inherited some hands from an old watchmaker shop, maybe some will fit - but I am not sure how to measure the diameter of such small a hole in hands (?).
Thanks for all your kind help - I really hope to bring this watch back to life (affectional value for us).
- caseback.jpg (99.28 KiB) Viewed 8538 times
- stem1.jpg (50.59 KiB) Viewed 8538 times
- stem2.jpg (27.39 KiB) Viewed 8538 times
