• The NAWCC Museum and Library & Research Center are currently open. Please check the Visiting Schedule for Days and Hours at the bottom of the Visit Page.
Removing dried crystal glue
Hudson777
Registered User
Oct 2, 2008
191
0
16
Is there a way to remove crystal glue from a bezel and glass hunting case crystal that is already hardened? I don't know if this was the UV kind, or the one that dries in the air, but whoever put it on did an awful job and I'd like to re-seat it.
Thanks
Hudson
Cary Hurt
Registered User
NAWCC Member
Dec 16, 2005
2,421
5
38
Country
Region
Thanks
Hudson
Hudson,
Try soaking the crystal and bezel in acetone for a little while. This will dissolve epoxy, as well as most other adhesives that I'm aware of. It won't harm a glass crystal or the bezel. Be careful with it, as it is highly flammable and has noxious fumes. It's available in paint departments at most stores, or as nail polish remover in the make-up department.
Once the adhesive is soften or dissolved, you can remove the crystal and clean the bezel. You may need to use a larger crystal if the previous owner found it necessary to use that much glue.
My two cents,
Cary Hurt
Smudgy
Registered User
May 20, 2003
2,874
24
38
Country
Region
If it is crystal cement, alcohol will dissolve it.
Brian C.
Registered User
Jun 9, 2001
1,247
4
38
NH
Country
It maybe a fine watchmaker's crazy glue.
Brian C.
Don
Registered User
NAWCC Member
Feb 17, 2002
235
1
0
I have the UV kind and it comes off prety good using a sharp tooth pick.
No scratching on the metal this way.
Any way it works for me.
Don
rleegabe
Registered User
Oct 4, 2001
517
5
18
68
Alderwood Manor Washington State
Country
Region
Whether it's plastic or glass, I find a great cleaning product and cheap is soapy ammonia, you can buy it and any grocery store. I use it to soak my old movements and case before cleaning in the ultrasonic cleaner, it's also great on gold case's.
le arsi
Registered User
Jul 7, 2008
461
2
18
Philippines
Country
The reason maybe that you asked this thread is because the glue is really very hard and if any alcohol or acetone did not do the trick then try my way but in a very skilled way. You can use a mini blow torch or alcohol lamp and apply heat to the hardened glue. Do not burn! Of course you have to remove the movement and other accessories for safety.
514 Poplar Street
Columbia, PA 17512
Phone: 717-684-8261
Contact the Webmaster for perceived copyright infringement (DMCA Registration Number 1010287).
Copyright © National Association of Watch and Clock Collectors Inc (A 501c3 non-profit corporation). All Rights Reserved.
The NAWCC is dedicated to providing association services, promoting interest in and encouraging the collecting of clocks and watches including disseminating knowledge of the same.
